Master window switch
2002 TOYOTA 4RUNNER
233,000 MILES • 3.4L • V6 • 4WD • AUTOMATIC
MICHRUNNER
All door switches are functional except driver side. Can unlock all locks but has problem locking them and no control over front passenger window. Found a master switch at junk yard and same problem when it was swapped out. Where would the problem be other than the switch?
Oct 15, 2017 at 7:52 AM
MHPAUTOS
  • 31,937 POSTS
Check the loom through the door opening, you often find a broken wire in here, very common problem.
Oct 16, 2017 at 5:04 AM
