Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Isuzu
Rodeo
Brakes
Line
Replace/Remove
Master cylinder replacement
2001 ISUZU RODEO
200,000 MILES • 3.2L • V6 • AUTOMATIC
JAMESMMJ
MEMBER
1 POST
FOLLOW
I have replaced the master cylinder, but I cannot get the brake lines to bleed. What is the proper bleeding procedure on my vehicle?
May 11, 2017 at 7:42 AM
HMAC300
CERTIFIED EXPERT
try a power bleeder first it may work otherwise a mechanic is going to have to use his scanner to open valves on ABS unit so it can be bled.
May 11, 2017 at 9:40 AM
