Radio stays on
2002 FORD F-350
200,000 MILES
DOG STOP
I had my master cylinder replaced in my diesel truck, and now everything inside my cab has power - windows, radio, ect., works without the key in. Could this have happened at the shop? Do they mess with any electrical wires while replacing that part?
Nov 7, 2018 at 5:56 AM
BMDOUBLE
  • 1,139 POSTS
The wiring under the dash needs to be closely inspected for a short to power with possible smashed wiring. Another possibility is loose wiring from aftermarket alarms,sometimes if you have an alarm some shops will disconnect it to service the vehicle and not reconnect it correctly,this is only if you have one anyways.
Nov 8, 2018 at 9:21 AM
DOG STOP
I do gave an alarm, the kind that must be turned off with the remote or start the truck within one minute or it disengages everything. You think I should call them and ask if they did anything with the electric? Just do not know if they will be honest with me.
Nov 8, 2018 at 7:19 PM
If it happened right after then it sounds like they left a ground wire off. I would have them look at it again.
Nov 12, 2018 at 10:27 AM
