Master cylinder and power brake booster replacement
1993 FORD ESCORT
150,000 MILES • 1.8L • 4 CYL • FWD • AUTOMATIC
ASTILLER
This is a wagon, in great condition, carefully maintained from new. Recently, there was a lot of travel,in the brake pedal and the Ford shop replaced the master cylinder. There was no change. I went to a new shop who obtained a tech bulletin from Ford regarding revised brake master cylinder and brake booster for this car. Article No. 98-5A-15, 3 pages with diagrams. We now have to order the correct combination of both parts. Can you advise what number parts these should be. So, it is for a wagon, automatic, pre 1994. Is it two,separate parts and numbers, or are they combined? It is a bit confusing. It looks like the two pRt numbers on the first page of the article left hand column under automatic. "38" is stamped on the MC casing. AutoZone tell me they can get the parts.
Dec 6, 2013 at 10:29 AM
HMAC300
  • 48,601 POSTS
by now everything has been updated as the car is well over 20 years old. if it has abs then you may need a scanner to bleed it properly as sometimes there are air pockets inside the abs unit that can only be bled out with a scanner to hold valves open.
Dec 6, 2013 at 11:33 AM
