I replaced the clutch assembly on my car listed above LS model and had difficultly sealing a leak in the hydraulic line from the combination slave/TOB (Concentric slave). The leak was at the elbow (I say it's a tee) where the hydraulic line exits the bell housing into this plastic ell. The other end of the ell has the bleeder screw and in the middle of the ell is the feed from the reservoir. The leak was at the end of the hydraulic line where it seats inside the plastic ell. Well, after a lot of time and effort I managed to get it to seal. I then bleed the concentric slave with a pressure bleeder initially but to help speed things alone also used a vacuum pump at the bleeding screw on the plastic ell. And it appears all of the air has been removed from that system. The clutch feels good but I cannot start the car right now. It was starting at the touch of the key and running fine. Then one day I went to start it and suddenly I had a no crank situation. My feeling is its either the safely neutral switch or the key immobilizer. This is next after I resolve what I am about to ask you
With the clutch hydraulic system open for some time a lot of air got into the system. When trying to seal the clutch leak I was initially pressurizing the system dry (only air) just to see if it was holding tight. It was during that time I discovered the left front brake caliper had developed a leak. l replaced both front calipers.
Putting the pressure bleeder onto the same reservoir (the reservoir is shared between the clutch and the brakes) and started bleeding at the right rear brake. Well, I bled and bled and bled, an enormous amount of air with fluid has been purged from that point. I wasn't through there but when closing the bleeder screw it almost didn't close. It just kept turning until I took the wrench off and pushed the screw in while turning it with my other hand and finally it was screwing in. When it stopped I snugged it with the wrench and decided to move on. At least for now.
Going to the next wheel (left rear) I started bleeding it and got a similar response to a lot of air mixed with the fluid. I've probably put in 3.5 - 4 qt.’s of brake fluid. I’m getting clean fluid but I also still have air.
At that point, I started researching the issue and it seems that because of the time the system was open I introduced a lot of air not just to the brake lines but also to the master cylinder and the ABS modulator which, has enough lines coming from it to be confused with an octopus.
So, here is my dilemma: How do I get the air out of the entire system, from all places (components)?
Saying help would be an understatement.
Thanks,
Rick
Thanks,
Rick
Nov 27, 2020 at 7:13 AM
