I removed the master cylinder from my truck because it would not gravity feed the rear lines. Before removing it I disconnected the front port line on the master cylinder it was okay, but the rear port would not bleed. I figured air might be trap in the rear port. So I pulled it and bench bled it front and rear ports. All air was evacuated. Re installed master cylinder. I waited for quite awhile and there was still no fluid coming of the rear port on the master cylinder. Not able to do the rear brake bleed. Any suggestions? thanks for your time!
Aug 20, 2016 at 7:31 PM
