After replacing the master cylinder brake pedal still goes to the floor
1980 CHEVROLET CAMARO
78,000 MILES • 2.9L • V8 • 2WD • AUTOMATIC
GARY JACQUARD
Is it normal to see the master cylinder and power booster move a bit when braking? just got new master cylinder and calipers installed. Brakes improved but not by much, pedal will still go to the floor before stopping
May 4, 2020 at 8:36 AM
Good afternoon,
Did you bleed the system? It sounds like you have air in the system. I would pressure bleed the system as there may be air trapped in the lines.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Yes, it is not abnormal for the firewall to flex a little when applying the brakes.
May 4, 2020 at 9:55 AM
