its leaking around the cap where you put in the fluid
the rubber seal inside the cap is tore brake fluid is leaking out around the cap the master cylender cap where you put the brake fluid in is leaking when you push the brakes the fluid is coming out around the cap
May 18, 2013 at 11:15 PM
