I had oil leaks all over my father-in-law's van listed above EX model. I replaced the valve cover gaskets and oil pan gasket torqued all bolts to spec and used Fel-Pro gaskets. it ran great for a day or two then noticed oil burning off of the exhaust. stopped and checked it out oil was on the passenger side all the way down to the back of the car from driving, what a mess about quarter and a half 2 quarts of oil. mind you I just did an oil change so got back home filled the oil back up let it sit in the driveway while I was underneath it for about 45 minutes not one leak or drip anywhere. drove it for about 10-15 minutes down the road started leaking again. pulled over immediately looking underneath can't find the leak anywhere. Please help me; where should I look the oil filter is fine, no leaking around there. It's on the back side of the motor on the passenger side, nothing on the driver side or transmission side. I'm lost here and can't find it. please help.
Mar 24, 2023 at 2:28 PM
