Mass air flow sensor low circuit and up stream 02 oxygen sensor bank one sensor circuit?
1999 CHEVROLET MALIBU
2,304,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
AKATONY
when I start the car up and let it warm up and when I start to drive for about 30 minutes or what not the engine stalls at the red light.
Oct 3, 2024 at 11:06 PM
What are the code numbers please? I have seen the MAF short out and cause stalling, I would unplug it to see if it makes a difference. Here is the location and how to get the codes for us:
This guide can help as well:
https://www.2carpros.com/articles/engine-stalls
Oct 4, 2024 at 12:13 PM
AKATONY
How do much does it cost to fix it for from cutting off?
Oct 4, 2024 at 4:38 PM
That is hard to say until we figure out what the problem is. I could be as simple as a loose fuse and as involved as a rebuild PCM. Did you try unplugging the MAF sensor? Also, what are the code numbers?
Oct 5, 2024 at 9:36 AM
