Hello, this code is P0113 (Intake Air Temperature Sensor Circuit High - Bank 1), so it does not indicate a MAF problem. This vehicle has an Air Charge Temperature Sensor that receives this signal. This code requires some electrical diagnosing, but I can walk you through it if you have access to a multimeter.
Please see our guide on how to use a multimeter below:
I will attach the guide for diagnosing this code also as pictures.
(See pic 01, 02 & 03)
Below I will include the procedure to replace the sensor, it is fairly straight forward.
(See pic 04)
1. Turn the ignition OFF.
2. Disconnect the IAT sensor harness connector.
3. Remove the IAT sensor by pulling it out of the air cleaner housing.
Hope this helps,
William
Aug 14, 2024 at 7:30 PM
