I started off with one code for the mass air flow sensor. I pulled the mass air flow sensor and housing out, cleaned with MAF cleaner and replaced it. The car was fine for a year or so. Recently the check engine light came on I reset the codes and it came on again. At this point I figured it was time to replace the MAF. After replacing the MAF sensor with a SKP part from Rock Auto I take a drive down the road and back with no issues in performance. While I’m driving back the check engine light turns on and I get 10 codes! Still the car feels normal and runs normal as far as I can tell. So I figure the MAF sensor is faulty so I put the old OEM MAF back on same ten codes. Now I should add that while tightening the two bolts that secure the MAF sensor to the air filter box I created a hairline crack that can be seen from the indiscriminate of the housing. I was told by AutoZone this shouldn’t be an issue just to put some JB weld on the crack. Really need help on this one before I spend money I don’t have. Appreciate anyone’s help thank you very much. Error codes I’m getting: P0174 Bank 1, P0171, P0172, P2187, P2188, P0174 Bank2, P0175, P2189 and P2190.
Oct 3, 2019 at 4:32 PM
