Check engine light came on had it scanned at AutoZone. Code came up as needing to replace mass air flow sensor. Bought one on-line worked for about two weeks check engine light came on again. Return the part for a refund bought a different one from a different company. Same problem. Have tried 4 different ones from different companies all do not correct the problem.
Engine starts ruff doesn't shift properly and along with the check engine light, the VDC and the slip light is on.
Jul 15, 2020 at 12:37 PM
