Mass air flow sensor reading p0100 code?
2013 NISSAN VERSA
100,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
VANVERSA
  • 6 POSTS
I have a p0100 reading from Bluedriver diagnostic tool. I replaced MAF still have bad code. I realized 1year ago a rat had eaten away at the lt/grn wire leading to MAF. I did check power at the harness and that wire has less volts than the rest. Can this be the issue obd bad code? If so, how to i fix the wire with solder or splice it what type of wire?
Mar 11, 2025 at 6:59 AM
Was the wire repaired? if not, this can be the problem. Here is a guide to help test the connections and the MAR sensor wiring diagrams so you can see which wires need to be tested.
P0100 - Mass Air Flow (MAF) Sensor Circuit Malfunction
Mar 11, 2025 at 2:05 PM
VANVERSA
  • 6 POSTS
Hello, thank you for your quick reply and help. I have not repaired the wire. What gauge wire would you recommend 18 -22 ?
Mar 13, 2025 at 2:37 PM
I would match the wire that you are trying to repair. Do you have an image you can upload?
Mar 14, 2025 at 8:31 AM
VANVERSA
  • 6 POSTS
Hereis the image of the chewed wire. I believe its 18-20. Let me know if the image didn't upload.im going to cut out the bad part and repair it by joining the wire and shrink wrap with solder wire connecter. What do you think?
Mar 14, 2025 at 8:44 AM
Yep, that looks like 18 gauge, you are on the right track to fix the problem, good find btw.
Mar 15, 2025 at 9:45 AM
VANVERSA
  • 6 POSTS
Hi Ken, well, all codes cleared for a few days now its back. I also replaced a neutral safety switch after market. You think I should get OEM and try that?
Mar 25, 2025 at 8:19 AM
Yep, that is what I would do, also please check for leaks between the throttle body and the MAF sensor. I would check the engine for excessive blowby as well.
Mar 25, 2025 at 1:26 PM
VANVERSA
  • 6 POSTS
Thank you. I will let you know.
Mar 26, 2025 at 6:29 AM
That would be great.
Mar 27, 2025 at 8:35 AM
VANVERSA
  • 6 POSTS
Hi Ken, I'm waiting for Safety switch to come from Nissan. I'm going to try OEM part. It also dawned on me that I put a reverse camera in. Would it be possible to get p0705 code if it a loose connection. Again 2013 Nissan versa? Today I will disconnect it and see.
Mar 31, 2025 at 6:57 AM
I can help you but, we only handle one problem per thread, please post your new question here, you must be logged in.
Mar 31, 2025 at 12:09 PM
