MAP sensor location
2007 SUZUKI XL7
110,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
AARONDAHL
Where is the MAP sensor located on the vehicle listed above limited edition?
May 23, 2018 at 3:18 PM
Hi and thanks for using 2CarPros.com. The MAP sensor on your vehicle is located below the throttle body air intake. I have attached a picture to help locate it.
Let me know if you have other questions or need additional help.
May 24, 2018 at 7:39 PM
AARONDAHL
Picture does not look the same as my motor even.
May 31, 2018 at 2:32 PM
I think this car has a MAF sensor not a MAP. This is what the book shows (below).
This guide show help as well:
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
May 31, 2018 at 2:36 PM
AARONDAHL
I changed the mass air flow sensor (MAF), but even if it do not have the oil pressure gauge in the vehicle it should still have a manifold absolute pressure sensor (MAP)? I cannot find the location of the MAP sensor. And I cannot find anything online about any of it and to send this to a dealer would be too expensive.
Jun 3, 2018 at 6:35 PM
Is this an overseas car?
Jun 4, 2018 at 10:11 AM
AARONDAHL
I got it from Grand Forks North Dakota, but my friends computer would not hook up to it, so I am thinking it is.
Jun 4, 2018 at 1:12 PM
That could make it a different configuration. Can you take a picture of the engine and bay so I can see what is going on?
Jun 4, 2018 at 6:40 PM
