Code 106 for MAP sensor
1999 MAZDA PROTEGE
150,000 MILES • 1.6L • 4 CYL • MANUAL
WILLIAMDAISE
  • 25 POSTS
Have a code 106 MAP sensor circuit out of range or maybe MAP sensor replace. that is the only code. I had the code before.
Oct 27, 2020 at 7:27 AM
There are a few different things that can cause the code. I noted that you indicated you had the code before. What was done? Did it fix the issue for any amount of time?
If you look at pic 1 below, I provided the likely causes of the code. Take a look through them and let me know if you have done anything with what's listed.
I also provided the diagnostics for the code (pics 2 and 3). However, I don't know if you have the test equipment needed. Let me know.
Oct 27, 2020 at 1:31 PM
WILLIAMDAISE
  • 25 POSTS
i didn't know an EGR valve had anything with the MAP sensor. just had a code for a MAP sensor. no testing on it yet. all i have is a launch scanner emu scanner does not have a pid for the Mazda. i was going to the testing i have seen on YouTube other words the MAP valve could be causing the problem. also fuel trims seem normal at idle but it's misfiring. thank you
Oct 28, 2020 at 11:29 AM (Merged)
I need to confirm something. Is this the same vehicle that I replied to earlier regarding the manifold absolute pressure sensor?
If it is, anything that can cause pressure differentials can create an issue.
