Codes P0106, P0108, P0113, MAP Sensor?
2014 AUDI Q5
120,000 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
DRCHUNGK
Vehicle listed above TFSI (Petrol) 2.0 with CNCD Engine.
Check light randomly comes on. OBD Scan Tool found the following errors:
P0106, P0108, P0113
These are related to Intake Air Temperature Sensor and Manifold Absolute Pressure sensor
I need help for finding the exact part number and location of the two sensors.
Oct 22, 2022 at 4:54 AM
I'm not sure why, but I am only showing the engine options below. Are you located in the US? Sometimes they are different when produced for a different country.
I tried to look up the codes for the CPMB flex fuel vehicle, but most of the codes you have aren't listed.
See pic below.
Oct 23, 2022 at 4:58 PM
DRCHUNGK
This is made in Germany and I'm in Australia. The image from obd scan tool is attached. I can see the codes listed on ross-tech wiki. I cannot the location, quantity, or part number for the MAP and IAT sensors.
Oct 23, 2022 at 6:51 PM
I would be happy to provide any information from the manual I have, but I'm not sure if the engine code will make a difference. They can.
If you want, let me know which one you feel is similar to your vehicle. Is it the flex-fuel or the hybrid?
Oct 24, 2022 at 5:45 PM
DRCHUNGK
It's the petrol (not sure what is flex fuel). Thanks
Oct 24, 2022 at 5:48 PM
Flex fuel is petrol that has a higher amount of ethanol. They sell it here in the US. It's less expensive, but you get less MPG. LOL
Since it isn't a hybrid, I went with the flex fuel.
Pics 1-7 are for the P0106. Note, pic 2 indicates checking the charge air pressure sensor. Pics 3 to 7 are the procedure.
P0108 doesn't exist for this vehicle. See pic 8
The remaining pics are for the P0113. It is set up the same way as the P0106.
Let me know if this helps.
See pics below.
Oct 24, 2022 at 7:41 PM
