Malfunctioning air conditioner
1991 TOYOTA TERCEL
150,000 MILES • 1.5L
EDWARD I WILLIAMS
The system was vacuumed and recharged with gas but the fuse behind the glove box was blown so I replaced it. When I turned on the A/C, the clutch engaged but the fan would only blow hot air into the car. After turning the A/C on and off a few times the fuse blew out again.
What items should I check next?
Jun 21, 2019 at 11:25 AM
Good afternoon,
What fuse number did you replace?
https://www.2carpros.com/articles/how-a-car-fuse-works
As far as the AC, do you have gauges to give me the high and low side readings while it is running?
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Jun 21, 2019 at 11:34 AM
EDWARD I WILLIAMS
There is only one fuse for the A/C on my car.
Jun 21, 2019 at 3:26 PM
Okay, is there power on both sides of the fuse?
Jun 21, 2019 at 3:40 PM
