p1753 code?
2002 HONDA ACCORD
LOKA
Had car put on test machine and shows p1259 variable valve electron control system bank1. And shows p1753 A/+ lockup solenoid A can you tell me what to do to fix it ? What does this mean what repairs do I need ?
May 17, 2013 at 3:38 AM
KHLOW2008
  • 41,814 POSTS
P1259 is a fault with the VTEC pressure switch and can be due to low engine oil level or clogging in the oil lines due to sludging. Check the oil level and try cleaning the V-TEC valve.
P1753 is a fault with the lock-up solenoid circuit. Check for bad connections at the connectors.
May 17, 2013 at 8:11 AM
MISTY ZIPF
  • 6 POSTS
I started having a slight problem with it shifting months ago and then it got really terrible stalling every time I came to a stop, we ended up buying a car with a blown motor the exact make and model for parts .. My husband who is a decent mechanic changed the transmission, only to find that it still isn't shifting correctly. we attempted to swap the (ECU) computer that was under the carpet behind the radio, but then it would not start at all. we looked at the ECU and did not see any visual issues nothing looked burnt or broken and it did not smell like it had gotten hot? We attempted just to reset the ECU, but it did not seem to make much difference. It will shift into gear but you almost have to start at first and work your way up manually, but does well in D4 although the D4 light does not come on. Help me please! Any suggestions?
Jun 15, 2021 at 10:11 AM (Merged)
Please clear all codes and then turn the ignition key to the "ON" position. The idea is there are too many codes to start looking at stuff, we want just the most prevalent ones so we can go from there.
Please run this test and get back to us so we can continue helping you.
STEVE W.
  • 15,113 POSTS
P0700 - Transmission control system Malfunction
P0753 - Shift Solenoid A Electrical
P1753 - Torque Converter Clutch Solenoid Malfunction
P0141 - Bank 1 Sensor 2 Oxygen Sensor Heater Circuit Malfunction
P1166 - Bank 1 Sensor 1 Oxygen Sensor Heater Circuit Malfunction
First thing I would check is the wiring harness around the engine for damage, either hitting the exhaust or rubbing through on a sharp corner. These codes all suggest an electrical problem rather than mechanical failure in the trans, especially as you can shift it manually.
As for swapping the ECUs, Most vehicles these days have some form of security system that will shut off the power to the engine, ignition or fuel pump if any part of the system don't match up. In your case the ECU is coded to the specific VIN of the vehicle. Unless you re-program the ECU to match that VIN the spare won't work.
Nice work Steve W :)
MISTY ZIPF
  • 6 POSTS
All codes cleared except the P0141 and it pops back on so I replaced the sensor but the code is still popping back up and the D4 light doesn't come on while driving?
STEVE W.
  • 15,113 POSTS
Check the wiring and the power to the sensors heater. Broken wire to the heater in the sensor will cause this code.
MIANAKRAM
car transmission does not make it move strongly very poor pulling when on D scanner give p1753 code there to many solenoids in confused which one i have to replace i already change the ecm.pl.i need your help
KHLOW2008
  • 41,814 POSTS
Hi mianakram, P1753 = Lock-up solenoid. However this solenoid should not interfere with the shifting process. Only the lock up would not engage.
https://www.2carpros.com/forum/automotive_pictures/192750_EngComp98Accord_1.jpg
BILLBUHRMAN
I have searched the web and found many different directions to go on this code (P1753), however none of them seem to agree on what the problem is or even could be. Can someone please give me a direction to go and the first 3 to 4 step to take to track down this problem?
DOCFIXIT
  • 18,828 POSTS
Hi see diagram
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_3_71.jpg
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_241.jpg
Locate lock-up solenoids code is for A with ohm meter check from Terminal 1 to body ground 12-24 ohms. Next take jumper wire from batt pos. touch to term. 1 does it click. failure of either test replace solenoid. Hope this helps Thanks for donate
