making grinding noise when you step on brakes
2006 BUICK TERRAZA
151,000 MILES
GINAPROV
When you step on the brakes they make a grinding noise (just replaced brake pads in April), traction control turns on when turning a corner and abs/traction control/stability light comes on randomly. Have replaced hub bearings and sensors in front. None of this has cleared the problem.
Aug 23, 2013 at 11:19 AM
HMAC300
  • 48,601 POSTS
scan for codes on abs if light is on then check for rust on brake rotors sometimes that causes it.
Aug 23, 2013 at 12:10 PM
GINAPROV
have tried both of those, have replaced sensor 2 in hub bearing
Aug 23, 2013 at 12:12 PM
HMAC300
  • 48,601 POSTS
if it's still coming on then it needs rescanning it may be something else.check for rust on other side and have brakes checked if grinding when applied.
Aug 23, 2013 at 12:27 PM
GINAPROV
They just put a scan on it yesterday and nothing came up, the took all 4 wheels off and can not find anything, brake pads still good also
Aug 23, 2013 at 12:30 PM
HMAC300
  • 48,601 POSTS
is there something plugged into the aldl at the lh bottom of dash? if there is that may be the cause of your problem with the light coming on otherwise it's an intermittent problem and unless they can bring something up on freeze frame while doing it then it will be hard to find. If there is something plugged in as that can cause it as well. Still check for rust. if the pads were replaced and rotors were not turned then sand down both sides and or have rotors turned or replaced. this could also be maybe parking brake adjusted to tight. Other than that I have no other suggestions...
Aug 23, 2013 at 12:41 PM
