major engine miss only when engine is hot
1987 FORD E-SERIES VAN
110,000 MILES • 5.0L • 6 CYL • RWD • AUTOMATIC
GLASS ARTIST
This is starting to p**** me off guys ;) Listen to this, only when the engine has been running for at least 15 minutes it start to miss a little then becomes major to a point that I have to stop and the first time got it towed to my mechanic... 1st time he flushes and cleans the throttle hoses I think (bare with me, give me glass and fire and I'ill make a work of art, but engines I know nothing). I leave with it and the next day it starts again... This time he say a loose wire on one spark plug and thinks that was the problem... Now get this, this Canadair camper van was inspected up the yahoo when I bought it this march and afterwards did 20 000 miles since then... I had changed ALL the filters, all liquids are regularly checked, no fuel pressure problem, no vacuum or air leaks, mechanical pump is fine, relay fuses as well, I can kick down no problem cause transmission is fine, even the catalytic converter has been changed !! Rev's perfectly when cold and so only after 15-30 minutes when hot does it start to miss fire and not with the pedal to the metal but with regular cruising power... H E L P !! This is my baby and home away from home when I do my craft shows.. As an artist, I aint rich you can imagine, so throwing away money on a mechanic to troubleshoot a problem is frustrating... Do you have any ideas ? Thanks a million for taking the time
Nov 4, 2015 at 10:21 PM
CAR-MAN145
  • 321 POSTS
I would have to check the coil or ignition module when they get hot they start breaking down and when they cool off they work till they just don't work anymore.
Nov 5, 2015 at 1:13 AM
GLASS ARTIST
1st off thanks for the very quick response! 2nd the info has been given to my mechanic... I'll tell you if that worked :)
Nov 5, 2015 at 7:05 AM
