maintenence required light on all the time
2006 TOYOTA LANDCRUISER
EMZEE
I own an american made 2006 model landcruiser vxr.I live in Saudi Arabia. I gave for servicing here, but tgey could not resolve the problem.And also on the screen it always display "please insert correctt map disc".As ut is american made I cant find it here.Please advice menif I can get it online and also how to deal with maintenence reqd sign.
Thankyou
Sep 27, 2013 at 11:46 AM
WRENCHTECH
  • 20,761 POSTS
This system informs you when to replace certain parts or components and shows dealer information (if registered) on the screen. When the navigation system begins operating after either the information item's date comes or the driving distance reaches the "Information" screen will be displayed. This screen will appear every time the system is turned on until you touch the "Do not display this message again" switch.
To prevent this information screen from being displayed again, touch the "Do not display this message again" switch.
Push the "INFO" button to display the "Information Menu" screen and touch the"Maintenance" switch.
Touch the desired icon and input the conditions
Notice of "Date" :You can input the next maintenance date.
Notice of "Distance": You can input the driving distance until the next maintenance check.
When you touch the"Personal Event" switch on the Maintenance" screen the screen changes to the Personal Event screen Touch the keys to input the desired name and then input conditions.
After you input the date and/or distance, touch the"OK" switch. The screen then returns to the Maintenance" screen.
The following switches appear.
"Delete All" :To cancel all conditions which have been inputted.
"Reset All" :To reset the item which has satisfied a condition.
Touch the"Off" switch at the top of the Maintenance" screen to turn off the information screen.
When your vehicle needs to be serviced, the icon color will change to orange.
Sep 27, 2013 at 12:11 PM
EMZEE
Thanks for your reply.But the message os not been shown on the screen, its a sign light near dash board side other sign lights
Sep 27, 2013 at 12:21 PM
WRENCHTECH
  • 20,761 POSTS
I thought you had navigation system but here is without navigation
Engine Oil Replacement Reminder Light
This light acts as a reminder to replace the engine oil.
This light will come on when the ignition switch is turned to "ON", and will go off after about a few seconds.
When you drive for about 7200 km (4500 miles) after engine oil replacement, this light illuminates for about 3 seconds and then flashes for about 12 seconds with the ignition key is turned to "ON" position. If you continue driving without engine oil replacement, and if the driving range exceeds 8000 km (5000 miles), the light will come on after the ignition key is turned to "ON" position. The light will remain on thereafter.
If the light is flashing, we recommend that you replace the engine oil at an early opportunity depending on the driving and road condition. If the light comes on, replace it as soon as possible.
You need to reset the light after the engine oil replacement. Reset the light by following the procedure below:
Turn the ignition key to the "OFF" position with the odometer reading shown.
Turn the ignition key to the "ON" position while holding down the "ODO/ TRIP" knob.
Hold down the knob until the light goes off. Before the light goes off, it illuminates for 3 seconds, flashes for 2 seconds, illuminates for 1 second.
If the system fails to reset, the light will remain flashing.
Sep 27, 2013 at 12:26 PM
