I thought you had navigation system but here is without navigation
Engine Oil Replacement Reminder Light
This light acts as a reminder to replace the engine oil.
This light will come on when the ignition switch is turned to "ON", and will go off after about a few seconds.
When you drive for about 7200 km (4500 miles) after engine oil replacement, this light illuminates for about 3 seconds and then flashes for about 12 seconds with the ignition key is turned to "ON" position. If you continue driving without engine oil replacement, and if the driving range exceeds 8000 km (5000 miles), the light will come on after the ignition key is turned to "ON" position. The light will remain on thereafter.
If the light is flashing, we recommend that you replace the engine oil at an early opportunity depending on the driving and road condition. If the light comes on, replace it as soon as possible.
You need to reset the light after the engine oil replacement. Reset the light by following the procedure below:
Turn the ignition key to the "OFF" position with the odometer reading shown.
Turn the ignition key to the "ON" position while holding down the "ODO/ TRIP" knob.
Hold down the knob until the light goes off. Before the light goes off, it illuminates for 3 seconds, flashes for 2 seconds, illuminates for 1 second.
If the system fails to reset, the light will remain flashing.
Sep 27, 2013 at 12:26 PM
