Maintenance information needed
2018 FORD MUSTANG
8,000 MILES • 2.3L • 4 CYL • TURBO • 2WD • AUTOMATIC
ADF020
  • 9 POSTS
I have a 208 mustang ecoboost convertible. I am wondering:
1) How often and how do I change the fuel filter?
2) What tools and how do I change the automatic transmission fluid?
I know I need a pump for the transmission fluid but I am not sure which one, any help is appreciated!
Dec 31, 2018 at 6:14 PM
Good evening,
1. Once a year
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
2. Lift the car, use a big drain pan. remove all the bolts around the pan. I believe they are 10mm bolts.
3. No pump needed. just a funnel and six quarts of fluid.
Dec 31, 2018 at 6:27 PM
ADF020
  • 9 POSTS
I have seen images like this, what is this things purpose if not to drain transmission fluid?
Dec 31, 2018 at 6:44 PM
That is for removing the fluid from the pan. not needed.
When you remove the bolts, tilt the pan toward the drain pan to remove the fluid.
Use a funnel to install the fluid.
Dec 31, 2018 at 6:53 PM
ADF020
  • 9 POSTS
Where exactly do I install the new fluid?
Jan 1, 2019 at 12:36 AM
I am sorry. This transmission gets filled from under the car at the fill plug.
There are two transmissions and the one for yours shows this. I attached a picture for you to view.
the pump you showed earlier looks like a good tool to use to add the fluid. just be sure you do not overfill the fluid level.
Jan 1, 2019 at 4:42 AM
