It sounds like one of the fuses for the BCM is out, I would turn the systems on and use a test light to check the fuses, here is a guide and the fuse location as well:
If the fuses are all good it sounds like the BCM got shorted out but to be sure we should do a CAN scan, you can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
You can get a preprogrammed BCM by searching Google or Ebay. Here is how to replace the BCM in case a code comes up for it. Check out the images (below). Please let us know what happens.
Jul 13, 2023 at 9:29 AM
