Shut off while driving without warning?
1996 TOYOTA AVALON
222,332 MILES • 3.0L • V6 • 2WD • AUTOMATIC
505AVALON
While driving the car suddenly shut off. No loss of power (alternator is fine), no bog down (wasn't engine failure or fuel issue). Just complete instant shut down. When I tried turning the key, had full electric, but no starter engagement. No sound, clicks grinding. So just to trouble shoot I was going to pull the starter just to eliminate the possibility. Upon removing the main fuse box, I noticed two bare wires from underneath the box. I found the were both connected to the 100a main fuse block. I assume these are the issue, but I cannot figure out how to reconnect the two black wires and one white wire to the block, also do I need to run a fusible link to replace these two? If so, where do they run to?
May 14, 2025 at 5:15 AM
505AVALON
Also have to push the button next to shifter to get car out of park everytime I need to move the car.
May 14, 2025 at 6:25 AM
Can you upload an image of the problem please?
May 14, 2025 at 1:51 PM
