MAF sensor wire colors
2006 BUICK RENDEZVOUS
97,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
77BOB
  • 6 POSTS
Squirrels ate the wiring to my MAF sensor. A shop replaced them with all white wires but spliced to the original colors. Another squirrel ate them again. Because of the white wires I don't know the mapping. When I get back to the original wire colors I need to figure out which colors go to where on the new pigtail. What is the color map for the 5 wires on the pigtail? thanks
Nov 29, 2025 at 4:09 PM
STEVE W.
  • 15,113 POSTS
Rodents are such fun. Attached are the OE and aftermarket color diagrams. Or by terminals - Term A- Yellow (MAF Sens), Term B- Pink (battery power), Term C- Black w/White (sensor ground), Term D- Tan (intake air temp signal), Term E- Black (intake air temp low return).
Might I suggest adding some armor to the wiring, Similar to this https://www.wirecare.com/product-lines/rodent-resistant-sleeving
Nov 29, 2025 at 5:33 PM
77BOB
  • 6 POSTS
Thank you! Those colors match with the pre spliced wires I have! I'm off to buy a pigtail. My only remaining question is, from the perspective of this image of the connector, is the black/white wire on the top or the bottom?
I've been hit multiple times in the past few years including the wiring harness out of the fuse box which i had to splice. Thanks for the armor tip!
Nov 30, 2025 at 8:41 AM
77BOB
  • 6 POSTS
nevermind, i see black/white is terminal C and presumably the middle one. Which terminal is A, the bottom or top?
Nov 30, 2025 at 12:16 PM
STEVE W.
  • 15,113 POSTS
This should help. Have been dealing with rodent damage for years. Customer vehicles as well as my yard equipment. They chewed the wiring on my garden tractors and lawn machines enough that I rewired those with steel tubing and conduit to keep them away.
Nov 30, 2025 at 12:26 PM
77BOB
  • 6 POSTS
I found a youtube video that showed a vague image of the pigtail and based on that put terminal A at the front and E at the back. Service Engine Soon light went away and shifting is smooth again. Will test drive more later then permanently crimp wires.
Nov 30, 2025 at 1:28 PM
STEVE W.
  • 15,113 POSTS
Did you see the connector image I attached? Those are the terminals looking into the pigtail end. In your image with the pink insert terminal A is on top, E at the bottom. You don't want to mix them up because it can cause a lot of problems.
Nov 30, 2025 at 5:06 PM
77BOB
  • 6 POSTS
I did not see the image at the time i posted the youtube mention, perhaps i forgot to refresh the screen. Yes, that is the exact image i was trying to find to know which direction the terminals were ordered. I was able to pick out the tan and yellow position from the video and that is the order I set. It works well now and I'll print all these images for future ref. (yellow is A and at the top and pink is B just below it, correct?) Thanks for your help!
Dec 1, 2025 at 6:59 AM
STEVE W.
  • 15,113 POSTS
With it vertical and A at the top its Yellow, Pink, Black/white, Tan, then Black. So will you be having squirrel stew tonight? lol
Dec 1, 2025 at 1:53 PM
77BOB
  • 6 POSTS
LOL i should get some protein out of it given all the trouble it has caused. My next project is replacing control arms - i already have the torques for that. thanks for your help!
Dec 2, 2025 at 11:55 AM
STEVE W.
  • 15,113 POSTS
You're welcome. If you need any other info (I do have a good recipe for squirrel if needed LOL) Just ask in a new question. We try to keep different topics separated to make searching easier.
Dec 2, 2025 at 9:45 PM
