MAF Sensor wiring diagrams?
1994 MITSUBISHI MIGHTY MAX
100,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
PACIFICISLANDER
  • 240 POSTS
Need to know the vehicle listed above, Mass Airflow Sensor spec's on the wiring connector?
Aug 10, 2022 at 10:43 PM
Here are the engine wiring diagrams which included the MAF sensor and I have included a guide to help you check the connections.
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Aug 11, 2022 at 10:19 AM
PACIFICISLANDER
  • 240 POSTS
I need the specs of the connector pins/terminals such as the 5v/12v/MAF signal wire/ and others on the 7 pins.
Aug 11, 2022 at 1:31 PM
Sure, here you go. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Aug 12, 2022 at 10:23 AM
