I just replaced my MAF sensor January 3, 2019. Today the truck started doing the same thing it was doing before I replaced it. Engine surge at 2,500 rpm.
Unbelievable one of the contact wires is gone. This sensor cost me $127.00.
Cardone is suppose to be top quality part. Mean time my MAP sensor was bad also. Could the bad MAP sensor be causing the MAF sensor to burn up? Why is this happening? I had to take my oil pump back out and retime it with the distributor because the truck would start but would not accelerate. The rotor I noticed was pointing at about one o'clock instead of pointing directly to the number one plug wire. So I removed the pump and the spindle.
And reinstalled it with someone holding the rotor at twelve o'clock.
It fell right in place and when I started the engine.my problem was solved. But then I find my MAF sensor is bad again. What would cause the new sensor to default? I'm replacing the MAP sensor before installing a new MAF sensor. And hopefully this one doesn't go bad too. The new one lasted a month. No clue please help. JC
Feb 14, 2019 at 11:45 AM
