Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
BMW
535
Engine
Mass Air Flow Sensor
MAF code?
2012 BMW 535
128,000 MILES • 6 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
MEMBER
FOLLOW
Starts okay, but the RPMs fluctuates at times, have this code. Is that usually an indication it's a bad MAF?
Image (Click to enlarge)
Nov 16, 2023 at 10:39 AM
CERTIFIED EXPERT
The code usually indicates a failed or dirty MAF. Also, keep in mind there could be a corrosion issue or loose wire at the MAF.
Try cleaning it first to see if it helps.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/mass-air-flow-service
Try this and let me know the results. Also, confirm the connector is tight, clean, and undamaged.
joe
Nov 16, 2023 at 9:14 PM
