Runs rough and check engine light on, codes PO102, PO113 and PO117
2006 CHEVROLET HHR
150,000 MILES • 2.4L • 4 CYL • AUTOMATIC
MRS. AMERIKA
My car was running rough then the next day my check engine light came on and it gave me 3 codes from the code reader PO102, PO113 and PO117. so i changed the air filter and bought a new mass air flow sensor then erased the codes and drove it home. the check engine light came back on and it still runs badly.
Sep 23, 2020 at 10:04 AM
Most likely you have a wiring issue. I included the testing for the P0102 as I suspect if you fix that one, you will fix all the issue. These sensors share a voltage feed so the fact that they are all showing a low voltage code points to a short to ground issue with the wire. This means that there is a wire that is touching a piece of metal and it is throwing these sensors off causing the engine to run poorly.
Let's run through this testing and let me know what you find. Thanks
Sep 23, 2020 at 3:44 PM
