Hello. I have a heat issue any advice would be greatly appreciated. I replaced radiator with hoses. I did a x2 heater core flush. New thermostat. Replaced the blend door actuator. It has gone from no heat to Lukewarm heat. Not an air flow or fan or blowing issue as far as I can tell. Low mid high air flow changes with the dial. When it gets cold my check engine light comes on and says water coolant sensor but was tested and it in range. any ideas as to what could help? It takes a while especially in winter to get to the sweet temperature area. Fuses are good. Could it be a relay, or this car just have no heating capabilities? Thanks
Nov 25, 2021 at 6:23 AM
