Okay, this is going to be difficult for me because I don't have a wiring schematic in front of me specific to what you have. However, do this.
On nearly all vehicles, there is one constant power supply to both the coils and the injectors. So, one of the wires to each fuel injector and one to each coil should be the same color. With the key in the run position, those wires should have power at all times.
Since there is power available at all times at these components, we need a ground path to complete the circuit. So, the second wire at the connectors will be different from one coil to another and one injector to another. The ground path is provided via that wire by the PCM when an ignition spark is needed and when fuel is needed for a specific cylinder.
So, first, locate the wires that have the same color. With the key in the run position, check them for battery voltage. If power is present, then connect a test light alligator clip to the battery positive and probe the wire of a different color while someone cranks the engine. If there is a ground path present, the test lamp will strobe on and off.
Oct 29, 2023 at 6:32 PM
