One of two things. Either you have leaking air struts, or height sensor/wiring concerns. The most common are leaking air struts. This can be checked with a spray bottle of soapy water sprayed all over the rubber part of the strut, bubbles=leak=replace. I've also had wiring issues at the vent valve at the strut (rare). Most customers I've had chose to replace the air struts for a regular spring replacement kit. Retrieving the trouble codes is usually the first step, but as easy as the soapy water test is, I would start there. I don't have access to repair manuals at this moment so if you need additional help, I'll have to call for reinforcements.
Jun 25, 2021 at 7:55 AM
