Lower radiator hose replacement
1999 FORD ESCORT
173,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
PALACIO239
  • 12 POSTS
I’ve tried replacing the lower radiator hose but I’ve had no luck replacing it. I can disconnect it from the radiator end with no problem.would I have to remove the entire accessory bracket that holds the power steering pump AC compressor, and alternator as a whole? Really stuck on this, anything that could help would be greatly appreciated.
Mar 28, 2020 at 11:06 PM
Good morning,
Did you try going through the right front wheel well?
I would remove the right front wheel and the wheel molding and then you will have a better look.
The hardest part is the clamp. They can be tough to remove to get the hose to release.
https://www.2carpros.com/articles/replace-radiator-hoses
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Mar 29, 2020 at 5:32 AM
