Lower radiator hose replacement
2006 JEEP COMMANDER
131,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
MAICOL88
  • 9 POSTS
I have a leak from the bottom radiator hose. Getting it off and replacing it is not the problem. My concern is on how to fill it with coolant after. I’ve heard that I have to burp the system. Can anyone help? If there is a procedure on how to do this?
Jan 16, 2019 at 12:14 PM
Yes, the system needs properly bled. To make sure it is, once you reinstall the hose, you will need to remove the bleeder plug on the thermostat housing, install a barbed fitting so you can connect a hose for drainage, and it must be open when refilling the
I had to attache pictures for you to get the specific directions. Let me know if there is anything you can't read or if you have questions. Pictures 1 and 2 show location of the bleeder.
Jan 16, 2019 at 7:56 PM
