Lower radiator hose cold , no matter what I do to the cooling system, the hose it will not warm up or get as hot as the upper radiator hose or the heater core hoses..
Okay. First Let me say I had issues with my radiator cap.
I quickly replaced the cap.
Looked over the cooling system, and everything looked great ..
Okay.. Started getting cold here in Wisconsin , needed to run car's heater then without warning , the plastic tank on the upper part of my radiator blew out.
Bought a new radiator and thermostat ,flushed and filled cooling system ..
Using purge and refilling funnel..
Okay..
My truck has dual heater system and the front heater works great but the rear heater blows cool or cold air ..my temperature hand never runs hot and it rest between the c an h normal temperature.. All hoses hot to the touch but lower radiator hose cold to the touch ..
Can someone point me into the right direction, lol. Help..
Oh, water pump not leaking from what I can see and tell but my fan has a slight wobble. thank you ..
Okay..
Jan 22, 2020 at 6:58 PM
