lower oil pan torque specs needed?
2009 NISSAN VERSA
88,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
ZEUSZ282000
need torque spec and pattern for replacing lower oil pan.
Aug 9, 2023 at 6:01 PM
As far as the lower oil pan torque specifications, see pic below. The picture also includes the torque sequence.
Note: The manufacturer recommends using a gasket maker product. If that is what you are doing, make sure to follow the directions. Also, allow the pan to sit dry for at least an hour before adding oil.
Let me know if this is what you needed.
joe
See pic below.
Aug 10, 2023 at 1:38 PM
