Thanks for the reply. I have already been to 3 stores, autozone and orielly and napa and none of them had it but napa had one at another location which was far away from me. But I already have a bearing / bushing press kit but I do not have the exact size. So I am wondering if I even need to have the perfect size because of the way the bushing is built. It has those little rubber tabs on the opposite sides of the "flex axis". See "push here" that is what I am referring to. Also, see how thin the outer edge is? In order to have the perfect size, you basically might get your tool Stuck in the arm. I mean the press tool, has to be smaller that the outer edge otherwise it will get stuck in the arm. If I cannot "press here", it seems illogical that Honda would make that outer rim so thin if I had to press in it to get it to come out. Therefore it seems logical to me, that those are little tabs, which should allow you to press the bushing out without breaking the rubber. Plus you have to ask, "why are those little tabs even there"? Those side spots, which I am calling "tabs", have no function because the flex axis is opposite to those tabs. And the tabs do not support anything. So, I am wonder why it would require a special tool to remove the bushing? Any socket should work that is wide enough to hit those 2 tabs! See?
Nov 22, 2018 at 10:40 AM
