Lower end Rebuild Parts List
1999 CHEVROLET MONTE CARLO
60,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
RAYMOND SLATER
Spun a bearing and threw a rod on cylinder #2. Wanting to do a lower end rebuild only due to the low mileage. I am unable to find a lower end rebuild kit. So I am seeking a lower end rebuild kit parts list to build my own kit. Also in this event does the timing chain cover have to be removed and if so would it make sense to replace the timing chain and assembly at the same time?
May 18, 2016 at 11:38 AM
HMAC300
  • 48,601 POSTS
On a 3.8L inspect timing chain cover for damage in oil pump housing. Highly recommended to install Melling oil pump kit which gives better oil in engine. Try finding a crank kit, also replace the rod that spun and any others that have spun, they ovalize terribly and will do it again after install. Replace chain and gears as well.
May 18, 2016 at 12:08 PM
RAYMOND SLATER
This is my list so far... Anything Missing?
Timing Set
Timing Chain Tensioner
Gasket set - Lower
Connecting Rod
Bearing Set - Main
Bearing Set - Rod
May 18, 2016 at 12:26 PM
HMAC300
  • 48,601 POSTS
if the rod spun how is the crank? normally they get damaged as well, that is why I said crank kit which is crank and bearings. How about the rear main seal or is it included with gasket set? Silicone rtv you may as well get a new serpentine belt and tensioner as well.is the timing cover okay or is it torn up look in oil pump area and put Vaseline or KY jelly in oil pump when you install it so it won't have to be primed. whatever rod has spun the head will need to come off so you will need intake and at least one head gasket as well.
May 18, 2016 at 12:40 PM
RENEE L
  • 1,260 POSTS
Great Job HMAC300!
May 18, 2016 at 2:55 PM
