When I replaced the lower control arms the first time, I got instructions from your website. I appreciate everything you have helped me with, but I have gotten so tired of this truck that I have had a friend of the family that is a mechanic lift it and help me find out what is going on and we found out that the stabilizer bar/sway bar is the cause of the problems. It not only is bent and resting on both lower control arms, but it is the reason that everything else is going out prematurely. The stress it's putting on the rest of the drive train, suspension, and wheel components is just too much with the everyday strain that all of the parts go through on a regular basis. If you think that we could be wrong or you have any suggestions that might help, I'm all ears. I know I have said it already, but I appreciate all of your help and value your opinion. Thank you so much. I have been out of work for a while or else I would donate to your website again but as soon as I get back at it you best believe I will.
Jun 24, 2023 at 10:52 AM
