I separated the ball joint from the knuckle. took off the axle nut. dropped the sway bar down. took off the tie rod.but cant get enough clearance yet to remove the ball joint. the lower sway bar wont go down enough. I've seen it done on the other side. they moved the knuckle and spring off to the side and removed the ball joint . what am i missing here ? thanks
Jun 12, 2019 at 12:41 PM
