Good morning,
I attached the procedure below with some pictures for you. You will need a portable press for the removal and installation of the ball joint.
Tools Required
J 9519-D Ball Joint Remover and Installer Set.
J 23742 Ball Joint Separator.
^ Raise the vehicle and support the frame with suitable safety stands.
1. Tire and wheel assembly.
^ Place a floor jack under the control arm spring seat and raise it until it supports the control arm.
CAUTION: Floor jack must remain under the control arm spring seat during removal and installation to retain the spring and control arm in position or personal injury may result.
2. Caliper.
Important: Support the caliper with a piece of wire to prevent damage to the brake line.
3. Cotter pin and the nut (67).
^ Use J 23742 to break the ball joint loose from the knuckle.
4. Lower control arm (40) from the knuckle.
^ Guide the control arm out of the splash shield with a screwdriver while lifting the upper control arm with a pry bar.
Important: Block the knuckle assembly out of the way by placing a wooden block between the frame and upper control arm.
5. Lower ball joint (69) from the lower control arm.
Inspect
^ The tapered hole in the steering knuckle and remove any dirt. If the hole is out of round, deformed or damaged, the knuckle must be replaced.
Installation
Tool Required
J 9519-30 Ball Joint Remover and Installer Set.
1. New ball joint (69) into the lower control arm (40).
^ Press in the ball joint using tools in. The ball joint will bottom on the control arm.
2. Bail joint stud into the steering knuckle.
3. Stud nut (67) onto the stud.
Tighten
Tighten nut (67) to 115 Nm (84 ft. lbs.) and align the slot in the stud nut with the hole in the stud by tightening.
4. New cotter pin (68) to the stud.
5. Caliper.
6. Tire and wheel assembly.
^ Lower the vehicle.
Important: Check the front end alignment.
May 14, 2019 at 6:48 AM
