When the mechanics went to perform an alignment after changing my winter tires, they said that they found several issues, and fortunately did not go through with the service. They said that the lower arm bushings were extremely worn, causing some other damage. The rear busing would need to be replaced as well, and potentially something else depending on how it looked after they go going. They quoted a worse case (including parts, service, and the alignment) just over $2000. This seems like a lot! Is it unreasonable? I would appreciate any advice! Thank you!
Mar 25, 2016 at 7:43 PM
