Lower number two control arms
2011 LEXUS LS
72,000 MILES
MOGLE
460 model. dealer says replace lower number two control arms. Should I replace all control arms at once, or is just one side? should i replace upper and lower at the same time?
May 11, 2017 at 10:19 AM
HMAC300
  • 48,601 POSTS
what model car is 250/350/450 etc.
May 11, 2017 at 12:18 PM
HMAC300
  • 48,601 POSTS
see picture, all the bushing should be checked and replace what is worn. also will need front end alignment after.
May 11, 2017 at 12:22 PM
MOGLE
thank you. it is an LS 460.
May 11, 2017 at 1:18 PM
HMAC300
  • 48,601 POSTS
okay the first diagram I sent was wrong because of model. this one may be wrong as well because there is a difference between AWD and RWD illustration is for Rwd. Next time give all info like engine/transmission/Awd or Rwd /manual/automatic transmission. thanks.
May 11, 2017 at 1:32 PM
HMAC300
  • 48,601 POSTS
i messed up that is an upper not a lower this is also for 2wd, Awd is different.
May 11, 2017 at 1:35 PM
