Engine wiring diagrams camshaft sensor low voltage?
2004 CHEVROLET TAHOE
200,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
SWINT
Knock sensor low voltage, camshaft sensor low voltage,mass air flow low voltage,shift solenoid b low voltage.
Jan 12, 2021 at 1:20 AM
Good morning,
What was the voltage at these sensors?
Are there any codes set for this issue?
All sensors should have 5 volts and all actuators and solenoids need 12 volts. I attached the wiring diagram for you to view.
I would also check the battery to be sure it is good.
Jan 12, 2021 at 3:56 AM
