it had 249000 miles on it the AFM failed and wasted the cam. I did a total rebuild on the engine. Did a mechanical delete on the AFM installed engine and it started up very easy has 40 psi oil pressure runs smooth had it tuned, but it has no power and I only have fifteen inches of manifold vacuum and the tuner said the fuel trims are thirty percent lean. I did a compression test and I have 195 and 200 psi on all eight cylinders. I replaced the intake gaskets did not help pulled timing cover crank timing mark at twelve cam gear mark at six no one piston at TDC. any ideas?
Thank you
Thank you
Jun 15, 2017 at 5:11 PM
