Low pressure warning light
2013 HONDA CIVIC
44,500 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
YFAPMP
Can you reset the low tire pressure light without special tool?
Not a TPMS light just the low pressure light.
I cannot find it in the manual.
Feb 24, 2017 at 4:26 PM
STEVE W.
  • 15,113 POSTS
Have you checked that all the tire pressures are correct according to the door sticker?
If so and these tires have the correct sensors then you have an issue in the TPMS system itself, either a bad sensor, or a sensor(s) that isn't in the correct location. If that is the case you can use a TPMS tool to reset them.
Feb 25, 2017 at 4:32 AM
YFAPMP
Yes I checked the tire pressure and three tires were 20 psi and one was 32. So I adjusted all the pressures to 32 psi.
There is no way I can find, to reset the light. Some have suggested I go to custom settings in the menu, go to TPMS and initialize the TPMS, but the TPMS does not appear in the menu and I do not have a TPMS error.
I have not driven the car sine I corrected the pressure, others have suggested if I drive the car the "low pressure" light will go out.
I just got this car yesterday and am new to Honda's.
Will it reset itself or do I have to go to the dealer? Thanks for the answer.
Feb 25, 2017 at 5:29 AM
STEVE W.
  • 15,113 POSTS
If you set all the tires to the correct pressure on the door tag (whatever it is, the sensors and programming are fussy) Then start it and drive the sensors will report the pressures and the light should go out. TPMS sensors only turn on when they move a bit. Setting still they do not transmit.
Feb 25, 2017 at 5:56 AM
YFAPMP
Thanks, after resetting pressures, I drove about half a mile and light went off. Great Job! Thanks
Feb 25, 2017 at 7:37 AM
STEVE W.
  • 15,113 POSTS
You are welcome.
Thank you for using 2CarPros.com.
Tell your friends, family and anyone you like about us and please return with any auto related questions, we are here to help.
Feb 25, 2017 at 7:45 AM
