Low power when accelerating to pass or go up hill
1997 HONDA PASSPORT
244,000 MILES • 3.2L • V6 • 4WD • AUTOMATIC
STEVENMS03
I replaced the engine three and half years ago with one that had 155,000 on it. Every thing has run fine until about a week ago. I always let the car warm up for ten to fifteen minutes before I run it cold or hot weather. Once warm and ready to go I will drive for about twenty minutes and then I will have a problem. The problem is the when I have to accelerate fast to go up hill, to merge on the highway, or to pass another car there is a lag in the engine. The engine will rev up and I will be pushing 3500 to 4000 rpm's and i will then hear a clunking noise in the engine for a few seconds. I have noticed that the car shifts slow during this time causing the engines rpm's to rise. If i am driving at a constant pace everything works okay. It is only when I need quick acceleration that I am having this problem. Any thoughts of what to look for?
Feb 22, 2018 at 6:29 PM
STEVE W.
  • 15,113 POSTS
Engine revving but no acceleration to go with it sounds more like a transmission slipping from worn clutches and seals than an engine issue. When is the last time the transmission fluid and filter was changed?
Feb 22, 2018 at 9:14 PM
