Low power in acceleration
2002 NISSAN SUNNY
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
AKSII
Did a full service but still having problem with acceleration. It takes time to pick up speed. When climbing small hills, it loses power and slows down.
Dec 3, 2018 at 4:34 PM
There are many things that can cause a power loss. The first things I always question is if the catalytic converters are partially plugged or if fuel pressure is low. That is where I would start. Here are links that show how to check both:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Here is a link that discusses low power issues with additional causes.
https://www.2carpros.com/articles/engine-has-low-power-output
Let me know if any of this helps or if you have other questions.
Dec 3, 2018 at 6:18 PM
